Hi All,
My 2005 Catalina 34 mkII gets rainwater in the bilge when it rains steady over a few days. The water will build up high enough to trigger the bilge pump. The water comes in from the aft end of the bilge, but I can't remove the floor to chase it upstream due to the uniform fiberglass construction. I've tried to locate the entry point by hosing the topsides in dry weather, but that doesn't reproduce the leak. It must be a relatively small opening somewhere, because the bilge stays dry under light and sporadic rain. Anyone with the same problem, or any other forensic ideas?
