OEM Bimini support structure
4Winds
Jun 8, 2022
53
Hunter 33 Wilmington, NC
What is OEM mfr for 2005 Hunter 33 aluminum Bimini support structure? I need to acquire new struts (like in pic) and related parts. Hardest to find is the 2" jaw slide ....
Shopping right here at SBO SHOP might find your an answer and help to keep the forum alive.
You may find that the SS poles used between the fitting are a commodity item that you can buy in your local community.
4Winds
Jun 8, 2022
53
Great suggestion! I try to use the sbo shop whenever I can ... unfortunately, all of the fittings I need are "not in inventory" ...
senang
Oct 21, 2009
318
hunter 38 Monaco
In Europe a lot of boatbuilders use "NVEquipment" in the Netherlands for everything they install on their boats above deck, bimini, sprayhood, sunshades…… Maybe worth a try if no succes elsewhere.
39
Hunter 44 DS Deale, MD
If the SBO store can't help, I ordered this part at:
They worked well and look perfectly normal despite the weird color in the picture.
(This was before I knew that SBO store carried them).
