23.5 replacement parts
Apr 3, 2020
191
Hunter 23.5 Frenchtown, MT
While going over my boat looking for rain leaks I also discovered a couple items that I want to replace.
Lifeline stanchions: 3 of mine have the little plastic cap at the top, one is missing.
Lifelines: the white covering is worn through where they pass through the lifeline stanchions. Is it best to just remove the rest of the covering, or replace entirely?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Stanchion cap: do an internet search on "lifeline stanchion cap" to find the one that matches/fit your stanchions
Lifelines: very time-consuming to remove the cover..........if it was my sailboat I would replace them with uncoated 316 stainless steel...........lots of options..........remove and take each to your local rigger for a replacement, meaure and purchase on line from any number of lifeline suppliers, buy a replacement easy DIY kit from Suncor Quick Attach™ Lifeline Kits Archives - Suncor Stainless, which is what I did.
Apr 3, 2020
191
Thanks Dave, I didn't know about the build list on the forum store. Looks like I'll need to put a few things on the list...
MrEd
Jun 5, 2004
72
Hunter 240 Louisville, KY/ Patoka Lake,IN
Time to replace those lifelines. In all likelihood the amount of corrosion beneath the plastic will be shocking. Good luck.
