Passage 456 saloon upgrades
Feb 6, 2010
154
hunter passage456 kemah
Posting the latest upgrade I made on my 2002 passage 456 Discovery..we've been cruising full time since 2012 and I've always love solid ash battens inside a boat so I took the plunge..Happy to advise how I did this if anyone is interested..also I have started a Passage 450/456 Facebook page..hope to see owners share ideas here also
Beautiful. Tongue and grove or glued to battens
Jun 1, 2009
1,860
Hunter 49 toronto
Ralph
Great job
I did the exact ash batons in my aft cabin. There is a prior writeup on this
I’m curious about the porthole surrounds. Really like them
I note that you did led indirect lighting . Did the same on my 49, as the original lighting was horrible
Nice job. I’m impressed
Jun 1, 2009
1,860
Hunter 49 toronto
On my ash plank job, I didn’t go T&G.
I literally fastened a sheet of marine ply to the hull, kerfed it to fit, and then used stainless finishing nails
I though of vertical battens, but I’m a glutton for punishment
Did you T&G the ask you self. What finish?
ill find a posting of my original document
Really like the porthole surrounds
1,860
Hunter 49 toronto
154
Looks great also
Beautiful !
Care to share how you attached the battens to the hull ?
Tnx.
I had the battens milled with rounded edges..after measuring..cutting and dry fitting I applied liquid nails to back and then set the batten and used a pin nailer to attach until the adhesive set..pin nailer is a kin to a nail gun but shoots a thin braid that you really can't see ..great tip I was given.
Feb 6, 2010
154
There 2 inch battens with rounded edges..milled from white ash boards..3/8 inch thick. Had same woodshop make the port trim rings out of the same boards..he was a artist
Feb 6, 2010
154
Beautiful !
Tnx.
[/QUOTE
Applied liquid nails then positioned the batten and used a pin nailer ( like a nail gun) to attach tight til adhesive set..pin nailer shoots a thin serrated braid that's used to attach trim etc. Can't see the hole..it penatrates the ash and imbedded into the 1/4 inch teak ply that was original
Jun 1, 2009
1,860
Hunter 49 toronto
Could you pm me the contact info for the shop please? I’d be keen to get those rings made
thanks !
