Anyone re-rig OUTHAUL using low friction rings?
Apex
Jun 19, 2013
1,225
C&C 30 Elk Rapids
I am in process of rigging a new outhaul. C&C30mkII. I searched this forum, and googles but found nothing with low friction rings. Seems like a good application to have less clanging inside the boom.
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
More friction in an application where friction hurts. I like LFRs, but I don't think this is one (I used blocks when I re-rigged mine last year, but I did switch to Dyneema line (with polyester cover where needed). LFRs are really not good with polyester when 180 bends are involved.
Just keep a little tension on the line and no clanging.
@Apex, I am a :plus: with Thinwater.
I find the value in LFR's when the path of the line is less than 110º. Thus I am using them to just turn direction of a line.
In the outhaul you need to reverse the direction of the line. Using the block to add power with minimal to no friction (180º turn of the line reduces the force required by 50%)
Use of more than one block (pulley) and you can really reduce the fore needed to adjust the outhaul.
That does not happen with LFR as they add friction to the system when the line turns greater than 110º.
Apex
Jun 19, 2013
1,225
C&C 30 Elk Rapids
good info: found an article excluding outhaul as a use for LFR. I should have some blocks kicking around somewhere. I am going to dyneema lines to connect to the clew. Likely along the lines of this Harken 5:1
1,037
Farr 30 San Francisco
I have trouble believing that LFR are lower in friction than a suitably chosen block with bearings and such. I could be wrong, it has happened before.
Apr 5, 2009
3,327
I agree with @jssailem that LFR's are best for redirecting line and when there is not a lot of travel. I have seen them effectively used in a backstay tensioner that used 8 in cascade to produce a 64:1 purchase but the top ring only needed to move about 6" max.
I modified the factory internal 3:1 outhaul on my C30 to be a 12:1 by adding one internal cascade block and a second cascade block on the main sail clew. I used a good quality bearing block for the internal and a high capacity sheeve block for the external due to it having the full 12:1 purchase load on it. The 3:1 still uses 1/4" dacron double braid because it has limited load. The rest of the system is 1/4" Amsteel.
