I have recently taken an interest in anodes and underwater corrosion. In all the time I've had boats I've never replaced an anode, crazy right! My boat lives in a fresh water lake and I've never had a corrosion problem that I'm aware of. I've ask others at my marina if they know of anyone having corrosion issues and the answers were all "no." A few years ago I realized how easy it is to make a wiring error and cause a potential issue, in my case I installed an automatic bilge pump switch with non waterproof crimp connectors. I did fix that later. What really got me thinking was the fact that my dock neighbor converted his boat from diesel to electric. He has a 48 volt setup, that much voltage could cause damage fast if something was wrong.
I bought a hookah last year and I've been inspecting and cleaning the hull, prop and anode. It's not an easy job. The water is very merky making inspection difficult. The prop anode is probably the original from 2008. I cannot see any significant corrosion other than one rust spot on the iron keel. I decided to take it a step further and ordered some new aluminium anodes and test cell. It's too cold now to enter the water so the anode will have to wait until next summer. Last weekend I dropped the test cell in the water and began taking measurements. The good news is that my boat tests at the same hull potential with the shore power cable connected or not. But, the hull potential is only -0.180 volts. The instructions that came with the test cell indicated that the voltage will be lower in fresh water, but it didn't specify an acceptable range. A normal voltage in salt water would be closer to -0.900 volts.
Any input would be appreciated.
