I have a 1997 Hunter 40.5 and I have a broken roller on both mid-ship cleats. I have machined new rollers to replace all four in the two cleats. The aluminum cleats are bolted to the aluminum toe-rail with stainless fasteners. I believe that the fasteners are carriage bolts that engage a square opening in the cleat. So I loosened the mounting nuts which was very easy and leaving the nuts on the bottom of the bolt to protect the threads, I tapped the bottom with a 16 ounce hammer. No joy. So I soaked the heads and the bottom threads with PB Blaster for a couple days and periodically tapped the bolts. Still no joy.
I am certain that the problem is aluminum corrosion that has frozen the bolt into the cleat. I tried soaking the bolt and threads with vinegar hoping that the acidic vinegar would help to dissolve the corrosion. Well that didn't work either. Going up to a 2# mallet was non-productive too.
I have read that nitric acid will dissolve aluminum corrosion without damage to the actual aluminum, but I am not convinced this is completely true and if it is, I don't know where I could get any nitric acid.
I can replace the bolts so damage to them is acceptable. I am beginning to conclude that drilling the bolt with increasingly larger bits is the only solution.
Suggestions and comments from all of the experts?
