No Backstay?
Jul 30, 2018
62
Beneteau 321 Tawas MI
Reading a review of the Oceanis 34.1 and they note “no backstay”. I’m no naval architect, but does this give anyone else nerves? Is it expected you’re not flying spinnaker in heavy air, or some other design detail accounts for nixing the backstay(s)?
Jan 7, 2011
5,752
Oday 322 East Chicago, IN
Many Hunter‘s with a B&R rig have no backstay. I had a 28 footer with the B&R Rig. The spreaders are swept back a bit, which is enough to keep the mast from falling forward.
I haven’t heard of any B&R rigs failing by falling forward…but will follow responses.
Apr 5, 2009
3,170
I have never been comfortable with the idea of no backstay. There is a guy on this forum who has his Hunter set up with cameras and the amount of headstay sag it shows is truly alarming.
Jul 30, 2018
62
That’s a great point. I noted the aft swept spreaders but just have a hard time imagining in a good blow that would be sufficient.
Assuming the Beneteau engineers did their job as well as Hunter’s B&R designers I wouldn’t worry about the strength, but like any design decision it’s a compromise. The swept back spreaders are designed to provide a strong enough rig, but they make running downwind more difficult by interfering with the main.
7,520
Alden 50 Sarasota, Florida
One often overlooked consideration with rigging dependent on a single backstay is if it fails. While swept back spreaders can also fail, they share the load vs. a single backstay rigging which bears the entire load.
Apr 5, 2009
3,170
I would say that is a false sense of security. Given the difference in angle on the single backstay behind the mainsail and the dual aft lowers on the swept back spreaders, the loads on the rigging on a B&R is far higher than on a similar sized boat with a backstay.
Nov 6, 2006
10,121
Check out ocean racers and catamarans. Not many have backstays
Aug 2, 2010
531
J-Boat J/88 Cobourg
I think one of the biggest reasons to live without the backstay is the extra roach you can carry in the main. The only other way to carry that much up top is running backstays which are a lot more work.
Sep 20, 2006
2,952
Hunter has used the B&R mast on all their boats with no backstay for over 20 yrs., including the 49.
Dinghy's like the FJ, flying scott and Hobbie 18's do not have back stays.
It is a design that works for the use the boat was designed. Sailing in the northern latitudes - ocean passages - could be an issue in a "perfect storm". One picks their boat and their sailing waters.
Catalina 320 Dana Point
There's a Hunter 38 next to me and it has some "struts" that extend backwards from mast to cabintop, is that common to the Hunters without backstays ?
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Many owners of Hunters that have done Atlantic crossings have added backstays and staysails My boat has double backstay and swept spreaders
Sep 24, 2021
386
Our last two boats have had swept spreader, but also adjustable backstays. I'd hate to give up the ability to mess with mast bend and forestay tension....
Likes: Mechone
