I have found water pooling by the port aft corner of my aqua lift muffler. The water is not coming from the raw water strainer. The photos attached show a crack at the port forward corner of the muffler. This crack is where I believe the water to be coming from, but it doesn't look to be cracked on the muffler itself instead it looks to be below the muffler. The water runs aft and pools on the other corner showed in the picture. Please let me know if you have had similar problems or have any solutions. The pool of water usually gets big enough and drains into the build but I dried up most of it in the photos.
