After working on the cooling system of my Volvo Penta MD 7A engine including removing the manifold, flushing the block, replacing the water supply tube and installing a new impeller in the pump, water does not come out the exhaust. With a tip from a mechanic, I find that if I disconnect the hose from the thermostat at the point where it enters the exhaust (or maybe heat exchanger), and hold it down a couple of feet lower, that water begins to come out of it. I then put the hose back on and the usual amount of water then comes out of the exhaust. It continues to function normally but the next time I start the engine, no water comes out the exhaust unless I repeat the procedure of removing that hose.
