I have only had the boat 2 months, and its been in the water for one month. My first boat so i know nothing. I’m pulling the boat this week to repair a hole and thought i might paint the bottom… But now that i think about it… how am i even going to do it while on the trailer?? Can’t be done, right?Depends...........an unprotected hull in a freshwater lake, is vulnerable to both soft growth (algae and slime) and hard growth (shellfish) that contribute to fouling. Do you have fast-growing zebra and quagga mussels, two invasive, fast-growing fouling organisms? Do you clean it regularily?
Every boat sits on stands or trailers when out of the water, and you obviously can't paint when it is in the water....how am i even going to do it while on the trailer?? Can’t be done, right?
It can be done. You will need 2 to 4 - 20 ton bottle jacks, steel drums not the plastic ones, (or concrete cinder blocks) and 4x4. You just need enough to lift it off the trailer in order to pull the trailer out. Found this Lifting a C22 off its trailer ?I have only had the boat 2 months, and its been in the water for one month. My first boat so i know nothing. I’m pulling the boat this week to repair a hole and thought i might paint the bottom… But now that i think about it… how am i even going to do it while on the trailer?? Can’t be done, right?
Thank you @teacherspet --- I'm just not sure I'm brave enough to try that. This is usually the point where I call in the professionals.... I don't know... I'll chew on it a day or two.It can be done. You will need 2 to 4 - 20 ton bottle jacks, steel drums not the plastic ones, (or concrete cinder blocks) and 4x4. You just need enough to lift it off the trailer in order to pull the trailer out. Found this Lifting a C22 off its trailer ?
Hi @Leeward Rail -- That does sound pretty easy peesy. Don't have to buy anything but 2x6's.... Can you elaborate on that a little bit? The 2x6 part?Easy peesy.
No Jack's needed. Just need a bunch of 2 x 6s and the trailer tongue jack.
Cut the 2x6 into 18 inch lengths and make a vertical column by stacking/screwing them, laying flat in a square shape. 2 pieces
per layer.
Lower the trailer tongue, stick the wood column under the transom, raise rhe trailer tongue.
Boat will lift off the rear portion of the bunks... Paint under the bunks at the back.
Repeat process for the front.
At no point is the whole boat off the trailer.
Dangerous? So is driving a car... Or sailing a boat... Ĉar is worse.
Using the right paint. It lasts multiple seasons.
That is basically it. By doing one end at a time the boat is stable because half is on the trailer bunks.make a stack of layers from the ground up to the transom once you've got the tongue of the trailer lowered. Sound right?
Nice... I like it. I think even I can handle that LOL I've never been much of a handyman... But I'm learning. I'm kind of limited on power tools, also.That is basically it. By doing one end at a time the boat is stable because half is on the trailer bunks.
Here is a shot of the basic wood design.
This is the one at a mechanical shop that I took the idea from. Easily adjust the height. Just keep screwing new layers on.
In mine I made it in 2 sections so I could also use them for other tasks.
Leeward Rail is right - this is a do-it-yourself job, if you want to. That said, for about $2,000 it can be done for you by your local boatyard - your choice. In either case, you will need an anti-foul if you intend to leave it in the water - stuff grows in warm fresh water just like in salty. In the Great Lakes, you could pass an entire season (defined as the five warmest months of the year) without bottom scrubbing, but that is not the case in sunny Texas. Fresh paint on your bottom in summer and you will be lucky to get a full month without critters setting up homestead rights.Easy peesy.
per layer.
A less tool intensive option is to use concrete blocks. A couple of blocks stacked and maybe a paver or two will be necessary. You'll have to measure. A piece of wood on top will protect the hull from the concrete. Given the price of lumber these days, it may be less expensive too.Nice... I like it. I think even I can handle that LOL I've never been much of a handyman... But I'm learning. I'm kind of limited on power tools, also.
It's all good. I think I'll give this method a try. I really want to get a coat of paint on the bottom.
You have a point there.Given the price of lumber these days, it may be less expensive too.
Hi @dlochner - Appreciate your reply.A less tool intensive option is to use concrete blocks. A couple of blocks stacked and maybe a paver or two will be necessary. You'll have to measure. A piece of wood on top will protect the hull from the concrete. Given the price of lumber these days, it may be less expensive too.
The blocks come in different sizes, there are sometimes known as cinder blocks, building blocks, concrete blocks, etc. These are the blocks used to build walls.At my local Home Depot they have 2" x 6" x 8 ft.
Do you mean the standard concrete blocks you see everywhere? About 6" x 6" by a foot long or so? kind of hollow?
So you're saying get enough of those topped with a piece of wood to support the boat in the same manner as Leeward Rail's method?
What is a paver?
