29.5 owners
chp
Sep 13, 2010
440
Hunter 280 hamilton
Just curious for hunter 29.5 owners with the pedestal traveller. I have a Hunter 280 and would like to add a traveller. Mine is presently end boom sheeting mounted on the pedestal. In order to install one for mid boom sheeting I would need to change the boom to a heavier boom. Too expensive. Wondering how much travel do you get with pedestal mount traveller and does it give you any measurable sail control.
I like the end of boom main sheet attachment. With that stated, you may not require a heavy boom if you use multi blocks spaced out and use a backing plates in the boom, you may be able to use your boom.
Feb 11, 2019
37
Hunter 29.5 Bristol, PA
The traveler on the 29.5 is, indeed, rather short. That said it does provide sufficient length for doing most of what I would do with longer travelers I've had on other boats. For shaping the main going upwind, the length is quite sufficient. For 'dumping' the main on a blustery day it comes up short for two reasons: It's not quite long enough (although it's almost long enough) and the blocks on the traveler are not up to the load.
IMO, JR
chp
Sep 13, 2010
440
Hunter 280 hamilton
IMO, JR
Thanks for the info. Do you know how much actual distance does your traveller car have. I was looking at using the Harken system, but when you subtract the end blocks and traveller car size from the overall track length I can only get about a total of 16 inches of travel.
The traveler is a “fine” trim control system. The mainsheet is a gross trim control tool. In the normal lulls and puffs when you want to tweak the balance of the boat (keep her on her feet) the traveler is your goto tool. 16 inches is better than 0 inches. You can, when going to wind in light air position the boom windward on boat center. This is more than you can do with a fixed point mainsheet.
The real question is do you need or do you want to spend your boat budget money on a traveler. If so, it will afford you fine trim position control of your mainsail.
chp
Sep 13, 2010
440
Hunter 280 hamilton
I installed a traveller on my 1990 Mac 26s and it was the best thing I ever did. I could now sail to 15 knts without puting in the first reef just by playing the traveller. Hence my wanting one on the Hunter. Just as you mentioned its about the dollars. This setup would only give me 8'' either side of center. Is it worth it. I don't know yet.
For me, I would evaluate the utility of a hardware install.
How useful will it be on the boat based on the usual winds I encounter and the type of trim demands I do.
Racing: My sail trim activity is constant every puff and lull has me adjusting sails to squeeze as much power as I can out of the wind to push the boat through the water. A traveler with multiple smooth adjustments would be mandatory. Likewise the same type of fine trim adjustable hardware would be installed for the jib/Genoa sheets, to allow the block on the rail to slide fore&aft.
Cruising: my sailing style is more laidback. In the waters I sail the breezes are more steady. My boat came with an old school pin adjustment traveler and a 6-1 Mainsheet block. Typically I’ll set the windward traveler pin position based on the wind and point of sail before a tack. Further trim while on the tack is managed by using the Mainsheet. Not a lot of tinkering is done. Set course at the helm, adjust sails to wind on that bearing.Sit back and enjoy the ride.
Not sure how long you have had your new boat. Undoubtedly the boat sails differently than the Mac 26. I’d give her a run in different weather conditions to see what she does. Between the sailing characteristics and the style of sailing your decision may be revealed. You might rig a temporary set of lines and blocks (tweakers) to imitate the traveler adjustments to help evaluate the affect 8 inches of adjustment gives you.
