Wire mesh size for A/C and engine seawater intake strainers
4Winds
Jun 8, 2022
53
Hunter 33 Wilmington, NC
My 2005 Hunter 33' boat uses Shurflo water strainers in front of engine and a/c seawater intake pumps. What is recommended mesh for the stainless steel screen? 20? 50? The previous owner had a fine mesh on the a/c and a less fine mesh on the engine. Not sure what sizes they are but i am guessing 20 and 50, respectively. Is there an alternative recommendation?
Thank you!
Feb 10, 2004
4,245
Hunter 40.5 Warwick, RI
This may not be as helpful as you might like, but I use Groco strainers and they offer two types of baskets. One is stainless steel and the other is a poly basket. I use both interchangeably. Both are durable and the water flow is just fine. My aux and genset pump about 5 gallons per minute. Groco does not specify the size of the basket screen, but perhaps you can compare the attached pictures from Groco to what you have and make a decision.
Edited to add: I also use the same baskets on my A/C water input. If the "20" and "50" specify holes per inch, my baskets are probably closer to 20.
4Winds
Jun 8, 2022
53
yes this is definitely larger ... i am guessing 20 also. curious, what is the length and diameter of the screen?
4Winds
Jun 8, 2022
53
hmm the shurflo screen is 1-1/2" diameter and 3-5/8" long. I think i have a solution but nothing that can be achieved in less than 7 days. supply chain issues ...
Feb 10, 2004
4,245
Curious- Why is this a concern? Are you having constant strainer plugging issues or overheating? If it's not broken I do subscribe to the notion of not trying to fix it.
4Winds
Jun 8, 2022
53
the current "stainless steel" screen has disintegrated. I need to replace it. If I can find an appropriate piece of vinyl I'll make my own. Also, I need to get a gallon jug to measure water coming out of the boat, but I think the 50 mesh that was in it is too fine (I cleaned it two weeks ago and it is already beyond salvage) and was also slowing the waterflow speed. So a 20 mesh seems like what I want if i can get it.
Nov 6, 2006
10,244
Those strainers can be pretty coarse to reduce plugging and help flow. The air conditioner pumps are centrifugaland can generally pass things in the vicinity of 1/8" so 20 or slightly more open will not be a problem. The engine pumps can easily tolerate 1/16" so there, a 20 is fine as well. There are typically no smaller clearances in the systems than the pumps.
Likes: 4Winds
4Winds
Jun 8, 2022
53
I had come to same conclusion for same reasons after lots of second guessing. who knew sailing required plumbing experience :) thank you for opining :) As soon as I get a seller on ebay to confirm the dimensions of the shurflow steel screen I'm stocking up!
Likes: kloudie1
Dec 25, 2000
6,059
Our 1991 boat came with a Perko brand sea water strainer, model number - 0493006PLB, that serves dual heat pumps. The strainer has a screen hole diameter of .077", which seems quite adequate for the purpose, with no issues after many years of use.
Likes: 4Winds
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
The strainer baskets are actually expensive, it's less expensive to actually buy the whole strainer 50 measure larger anything less clogs really quick, also where your boat is located has a real bearing on how fast they clog up, I was doing mine every other day when at low little tide I think she was just pulling in mud,
4Winds
Jun 8, 2022
53
That sounds about right. I asked 6-8 vendors on ebay selling the shurflo screens and strainers if the "kits" (screen only) measured 1-1/4 x 3-5/8" (size of my 20 mesh screen), and not one had the slightest idea. These resellers do not know the products they are selling. So I bought one, will know the answer in about 5 days. I had a 50 mesh and it is too fine ... I really hope the screen fits, otherwise I will need to stock up on the whole asssembly, and they are more expensive($50-70) than the replacement screens alone ($24). Or change manufacturer.
