So the missing piece of information here is where and when?Next round of drinks are on me.
Glad you figured it out
dj
Same reason I found 1 of my 3) 12-volt outlets wired into the same breaker as the fridgeIt doesn't really make any sense that there should be 2 breaker switches and a switch in the head and each of the switches turn the water pressure pump and bilge/shower drain pump on and off simultaneously. You should be able to turn your water pressure pump on and leave it on without activating the bilge/shower pump. It is normal for a switch in the head to activate only a shower drain pump, I'll give you that.
How is it possible for you to activate the bilge and water pressure pumps independently from each other?
Well, this is logical ... that's exactly how my shower drain pump works. It is on the same breaker as the water pump but there is an on-off switch for the drain pump in the head.In the case of the water pump and shower sump, maybe the logic was
-the shower sump is only needed when the water pump is on…
- the shower sump has its own switch, so it can stay off when not needed, and the water pump is on
So why not put them on th same breaker?
I guess I'm sort of getting this ... still not exactly sure ... but perhaps this it!If the shower switch is in the off position then each of the bilge pump and water pump switches work normally and independently.
If the shower switch is turned on (- as it would be for a shower) both the water pump and the shower (and secondary?) bilge pump are powered together so that you don’t pump water - over flowing the bilge (bilge pump not on) or burning the bilge pump out by pumping with no water.
An interesting method to deal with these potential issues for sure. It also allows shower use to be controlled from the head even if only one of the two pumps is switched on at the main panel.
I thought the OP said that he didn’t realize the shower sump pump switch was on in the head…shut it off and all is well.I guess I'm sort of getting this ... still not exactly sure ... but perhaps this it!![]()
All of it seems so oddly put together and there is no explanation or diagram (other than the Beneteau plumbing diagram Ted provided) that I guess I don't really know what "all is well" really means. I'm guessing that @twalker H260 figured it out, so, since this really isn't my concern, I'm trying to put this out of my brain!I thought the OP said that he didn’t realize the shower sump pump switch was on in the head…shut it off and all is well.
At least that is what I thought to be the case.
Here, I will help you…I'm trying to put this out of my brain!![]()
