HI all,
This is probably the only group I could find active threads about the Yamaha 33, hopefully I could get insights from you guys with the 33.
Recently a friend of mine wants to get rid of his Y33 due to extensive leaking, having inspected the boat myself I'm on the edge whether to take it and restore it or let the guy scrap it.
My concren is not the leakage itself which I can definitely get to the bottom of it since they are only usual leakage from the gap between lens and hull. The big leakage was caused from the broken hatch which as you could imagine, when it rains it fills! But due to the flooding to the saloon, all wooden partitions are rotten. Therefore my concern would be whether I could do away with all interior partitionings as I'm afraid the ones going from top to bottom could be structural. If they are not then I could really change the interior layout since the head can be relocated.
The hull itself is not leaking so the integrity of the boat should be sound.
Thank you in advance for your advices and comments.
