Hi Everyone,
I have a 1979 Catalina 30 that I bought a few months ago from someone who didn't sail, just lived aboard. I am pretty sure that a prior owner was a serious sailor and rigged the boat to go as fast as possible. It is a standard rig with a bow sprit. There is a traveler over the companionway. The boom has a hard vang. The boom is bolted to the mast with three bolts, about 4 inches below the slots where one would load the sail slugs for the main. I stand 5'10" and the boom will hit me in the head if I don't duck. I want to raise it for safety and would like to add a dodger, because most of the year it gets pretty cold.
As I walk around my marina, it seems the other Catalina 30's have their masts raised 18 or more inches above mine. I haven't been able to meet any of the owners, and their sails are covered, so I can't really measure. In my case, if I raise the boom more than 4 inches, I will be unable to remove the sail slugs without removing the boom. Being a relatively new sailor, I don't know how bad an inconvenience this would be. I guess the prudent thing would be to replace all the slugs and maybe add a few extras for the inevitable breakage?
I am very respectful of the boom and how it is mounted. I can't imagine the force exerted at the goose neck, so I am not in a hurry to experiment moving the boom. Riggers are hard-to-come-by in Marina Del Rey in the summer months, so I am probably on my own, which is why I wrote this post.
The boat came with a main from a J 29 which did not fit correctly. Catalina Direct said all 30ft and up main sails are custom made and there is no correct size. I took a chance and bought a used main that had a longer luff and a shorter leech. It fits better but can only be tightened along the leech by tightening the vang..
The main can be raised 25 extra inches when I disconnect the tack and pull on the halyard. I don't know if the sail will be usable, but hope so. The center of the boom is 31 inches above the deck.
Attached are pics of my mast, gooseneck and vang. Anyone with experience, please share how much to raise the boom. Also, can the current gooseneck be moved, or should it be replaced? I haven't tried to remove any of the three bolts, xo I don't know if they are tapped into the mast or simply tighten against it. Also, will the hard vang need to be moved? Any thoughts will be very helpful.
