Which Sealant to Use for Bedding Stanchion
Sep 22, 2021
314
Hunter 41AC 0 Portland, OR
I ordered a stanchion from SBO to replace the one that I damaged. It arrived today and I've been pondering which sealant I should use for bedding it. I've heard some say that you shouldn't use 5200 on anything that you might need or want to take apart in the future so I'm reluctant to use that.
Recommendations?
Sep 22, 2021
314
Thanks. I've used butyl tape on my RVs over the years so I'm very familiar with it. I know that I've heard of 4200 in the past, the difference being that it isn't quite as strong as 5200. The existing bedding material appears to be a urethane type of sealant so I think I'll go with the 4200.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
The reason that everyone, including me, uses butyl tape (Bed-It being a particularly good brand, but not the only one) is future disassembly and long-term flexibility. While 3M 4100/4200 have good sealing properties, they also have high adhesion, close to the bonding between gelcoat and the underlying fiberglass. 5200 actually has higher adhesion, and you can pull off the gelcoat if you have enough strength.
Sep 20, 2006
2,955
The reason that everyone, including me, uses butyl tape (BedIt being a particularly good brand, but not the only one) is future disassembly and long-term flexibility. While 3M 4100/4200 have good sealing properties, they also have high adhesion, close to the bonding between gelcoat and the underlying fiberglass. 5200 actually has higher adhesion, and you can pull off the gelcoat if you have enough strength.
Bed-It is not a butyl tape and is a different formulation than regular butyl. It was dveleoped by Rod ( Compass Marine Inc / MarineHowto.com) specifically for the marine environment.
Bed-It Tape is NOT an RV, Masonry, HVAC, or glazing product. It was specifically formulated for use in bedding deck hardware.
-na -NA Anywhere USA
Never use an impact wrench for this stanchion. If you don’t see the nuts,, then the bolt is screwed into an aluminum plate within the fiberglass deck which the aluminum plate was drilled and tapped for that bolt size
Sep 22, 2021
314
I recently replaced all mine.
I ordered and have received a new base and stanchion from SBO. The SBO page indicates that 2004-2010 stanchions are slightly smaller diameter than those from 2011 on. On your 2005, was the bolt spacing on the old bases the same (2.0 inches) as on the new ones or did you need to re-drill? Also, what needed to be done to get access to the nuts on the underside?
Sep 20, 2006
2,955
Spacing was the same, drop in. I had to drop the wood liner above the nav station and settee on the other side. Don't remove the teak handrail. Not necessary and big pain to reinstall. Loosened plastic liner in v-berth and pulled down enough to get wrench in there.
I favor Bed-it Tape. I used it to bed the binnacle brace/guard on my boat. No leaks and firmly held in place.
