Slippery Strip For RIB Keel?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I'm having trouble pulling my RIB up onto the dinghy dock. Getting old, I guess.
I feel like I can do it, but the keel is just too sticky against the wooden dock.
I heard or saw sometime about a self-adhesive strip of UHMW polyethylene that one could adhere to the "V" of the hull, so as to make is slip and slide much more easily for this operation. I can't find it online. Any ideas?
Thanks,
jv
I don’t that product, but I used to coat the bottom of my hard dink with epoxy filled with a graphite powder - West System 423. It gave pretty good abrasion protection and left a slippery surface.
Is this what you were trying to find?
jviss
Feb 5, 2004
7,090
Thanks, but no, I don't think that's it.
Sorry, no experience with a strip of material like that, but I have started using a cheap furniture dolly to get my Dyer Dhow up and down the launch ramp. I screwed a couple 2x4 pieces on it to match the hull shape a little better, and tied a line onto it so I can pull it along in synch with the dinghy. Lots easier than just brute forcing it.
jviss
Feb 5, 2004
7,090
Thanks, but that won't work for me.
Dec 28, 2015
1,945
I’m afraid you won’t find a UHMW or HDPE that has adhesive strips. Nothing really sticks well to it.
dmax
Jul 29, 2018
1,347
Telstar 28 Buzzards Bay
You could make your own using a strip and adhesive from mcmaster-carr:
They have an epoxy that sticks to polyethylene though it's pricey:
They say this about their strips of UHMW:
"Strips with an etched texture have one side that’s scuffed to readily accept an adhesive; the other side is smooth."
Or you could mechanically fasten it with recessed screws (though holes in the bottom of the boat, not so good).
Dec 28, 2015
1,945
I think this is what I was getting at. You don’t see these types a materials bonded in larger masses because the bonding options don’t last or work well with the material. Thin tape doesn’t need much shear strength but increase the material to 1/8 and the bonding materials doesn’t work well. I was making wake gates for wakesurfing boats for a while out of HDPE and wanted to glue them together for speed. Nothing worked other than SS screws.
dmax
Jul 29, 2018
1,347
Yeah, I can't see the tape lasting long. It's great for quieting down comapnionway slides though.
dmax
Jul 29, 2018
1,347
Or you could take two strips of UHMW, screw them together to form an "L", round off the square edge and figure out a way to temporarily secure it to the edge of the dinghy dock whenever you need to haul the dinghy up. You could use a polyethylene cutting board for the material (cheap). You might want a lanyard with a float on it so it doesn't sink when it inevitably falls in. Here's a profile of what I mean:
