Stopping engine
Paulam
Apr 16, 2022
34
Catalina MK 1 Point Roberts, WA
It's looking like a matter of choice - as mentioned I have done keys first for over a year now and so far no problems
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
the alt continues to produce power until the engine (and alternator) stops rotating .
That's not so, Don. When the regulator is shut off, and there's no field current, there will be no alternator output, except a tiny amount due to residual magnetism. But the alternator rotating does not mean it's producing power, you need field current to do that.
Likes: Stu Jackson
May 24, 2004
7,209
CC 30 South Florida
That is incorrect, at least for most engines. Turning off the key will shut off the regulator, but doesn't disconnect the load (batteries) from the alternator.
Makes sense and it would explain why I accidentally never damaged the alternator. I guess the old timer I learned the procedure from decades ago was not an electrical engineer but he sure knew it was OK.
Likes: jviss
jviss
Feb 5, 2004
7,090
for someone like me the black art of electricity is now darker
It's not so hard to learn if you want to, you can learn it like building blocks. One way of looking at "zapping" things is to know you can't change the current in a circuit instantaneously, and Ohm's Law must always. be followed. So, if you have an alternator pumping current into a load and you suddenly disconnect it, the current is cut, and to satisfy Ohm's Law, (V-IR) the Voltage must suddenly increase - very high! This will exceed the withstanding.voltage of the diodes and burn them out.
That's why in older "points and condenser" ignition systems the condenser (capacitor) was there - to be charged up by the current when the points opened. Otherwise the Voltage would increase enough to arc, and burn the points.
Paulam
Apr 16, 2022
34
I'm an accountant (retired) I can build 20 year life of mine models but when it comes to electricity I leave it to the sparkies
11,758
Actually Don is correct. if this is the factory alt(leece-Neville) with key /on excite.. Once the alt is excited you can kill power to the excite wire and it will continue to work. the excite wire is only needed to boot it up..
Likes: heritage
jviss
Feb 5, 2004
7,090
Wouldn't that only be so if the key didn't also shut of the regulator? I'm referring to external regulators. I concede that I'm not familiar with all the internal regulator setups. (I thought Leece-Neville were somewhat archaic.).
That said, how will turning off the key with the engine spinning hurt a self-exciting alternator?
Really no more difficult than remembering which side of the line a debit or a credit are placed. It is all about perspective.
You just need to understand the rules. If it is not for you call an marine electrician, and chalk it up to 3 more billable hours.
I'm betting you also understand GAAP...
Some of my reading of the rules has been excellent bedtime reading. Puts me to sleep in less than a minute.
Apr 22, 2011
972
Okay, back to the ops question. Key or engine fuel shutdown first,. This morning I was out sailing and on the way back in while running the engine, I switched the key off. The alternator output immediately went to zero. I have a Balmar alternator with a 614 external regulator. The key controls power to the regulator and I assume that without a regulator the Balmar alternator cannot continue to produce power,. So, at least on my boat, it doesn't matter if you choose to turn the key off first.
Paulam
Apr 16, 2022
34
when you say alternator output went to zero - are you seeing that from the volt gauge on the panel?
Apr 22, 2011
972
from the shunt amp guage. and also
the engine rpms increased. no doubt that the alternator shut down when the key was off.
