While renewing the volvo shaft seal on my 1990 Beneteau 41S5 I couldnt get the shaft to go completely into the coupling. Lotsa banging on propshaft nut still leaves shaft 3/4 inch short of re-alinging with the countersunk bolt. Im at a loss what to do next. Tried heating- and aforementioned banging . Also drove cold chisels int slits where bolts are plus some propane torch heating. Thinking of trying to use the prop /engine force after launching to drive shaft forward but concerned that might damage keyway/key. HELP!! JUst what is the procedure here?? PS is it designed for the shaft to "bottom out" in the coupling???
