2005 Hunter 36 Shorepower
drm1
Sep 13, 2020
108
Hunter 36 Bayport Yachting Center
Hi we have a 2005 Hunter 36 with a Xantrex Inverter/charger. We have 30 amp shore power, and usually have a pigtail to connect to our two connectors for our dual sided AC panel.
we are on an extended trip and forgot the pigtail back home. Trying to avoid buying another one.
I connected the shore line cord to the connector for the right side of the panel, flipped the switch on, the light is on, but the battery charger isn’t charging the batteries. The ‘AC In’ light on the Xantrex isn’t lit.
any thoughts would be appreciated
Jan 4, 2006
7,444
Without seeing a wiring diagram of the boat, try supplying power to the left hand panel. If you have a diagram on board, snap a pic and we'll all have a look.
If that doesn't work, we'll wait for the next bright idea to come through.
Apr 8, 2011
774
Hunter 40 Deale, MD
I have a 2009 H36 and I think our panels and AC shore power connectors are likely identical. Just to confirm, you've plugged your single shore power connector into the port (left) 30a shore power connector on the stern of the boat as you face forward? That's powers everything AC on the Line 1 AC panel, and the right (starboard) shore power connector powers your Line 2 AC panel for the air conditioner. You MIGHT be able to run the air conditioner from the port (left) shore power connector if you leave the Line 2 switch off, and engage the Parallel switch. i know the manual says that works if you have a generator installed, but full disclosure, I've never tried it myself. BUT, be mindful that if you do try it you'll have to have most things off on your Line 1 AC panel or you'll overtax the 30a and the breaker in your port cockpit locker will trip leaving you with no power at all. Not sure if you can run your air conditioner AND your battery charger at the same time if Line 2 is in parallel.
Those breakers in the locker are probably something you'll want to check anyway in case they got accidentally tripped by pulling something out of the locker, or were tripped by overvoltage. Your issue may be that simple.
Likes: plenny7
JamesG161
Feb 14, 2014
7,936
Hunter 430 Waveland, MS
Does your normal pigtail plug into a 50 Amp Shore power?
My 2-30 amp pigtail goes to a 50 amp shore power.
Jim...
drm1
Sep 13, 2020
108
Answering m
thanks Ralph. No wiring diagram unfortunately
drm1
Sep 13, 2020
108
Thanks. Yes I think we have the same setup.
I reset the breaker, connected line 1, and the battery charger came on line. Took your advice, moved the slider up and switched to parallel and was able to get air con from line 2. Thanks for the tip …. Actually had never looked that closely at the sliders.
AndyL
Jun 23, 2020
153
Hunter 36 Rock Hall
FYI, we run our Air Con by using the parallel setting. We do not run the water heater or microwave while running the Air Con, nor would we do something that takes a high load from the outlets, like a hair dryer.
Likes: plenny7
Apr 8, 2011
774
Hunter 40 Deale, MD
We were able to run the air con and the water heater for the 4 days we were in port over the last 2 weeks. Didn’t try the microwave.
Excellent - glad we could figure it out. Really nice that Hunter wired those circuits so they could be run in parallel.
Nov 28, 2016
103
Hunter 36 Northeast, MD
We have a 2008 Hunter 36, use a 30A splitter to plug both 120VAC legs into a 30A shore power receptacle and run the whole boat without issue.
Apr 8, 2011
774
Hunter 40 Deale, MD
What you're proposing is exactly the same thing, functionally, as paralleling the two AC circuits on the boat. But I'd be leary that this would work to "run the whole boat without issue". Running everything at once (particularly with startup current spikes that an old rule of thumb says are roughly 5x the running amperage) is more than one 30-amp shore power receptacle could handle - the very reason why Hunter chose to split the power into two 30a receptacles with the a/c separated. A 16k a/c MarineAir a/c unit alone, which turns on and off as cooling is demanded, can require 73 amps briefly to start, though it runs much lower than that once it gets going. And with an EasyStart I can run mine off of my Honda 2200 - but even with an EasyStart capacitor it requires over 31 amps to get started. (See the Coastal Climate Control linked video here: MarinAire 16K Start Load Tests - YouTube ). If you added in a water heater, a battery charger, refrigeration, and whatever else you're running off of the AC Panel 1, I'd completely expect the breaker onshore to trip.
Sure, I can run "everything" off of a splitter, or by paralleling, but I have to do so judiciously - running the a/c without the water heater on, for example. The amperage draw is just too much otherwise.
Dec 25, 2000
5,953
Different model boat here, but our shore power setup is very similar. Boat has two 30 amp plug connections, A & B. Normally operate the boat with one cord on the A/B side that operates all AC connections. Very easy to exceed 30 amps, but I manage consumption at that level.
Charger/inverter - var.
Microwave - 10
Heat pump main cabin - 12
Heat pump aft cabin - 10
Water heater - 12
Entertainment - 5
Misc. - 5
Normally, if the house bank state reaches 12.2 VDC, which would happen if away from shore power for an extended period, the charger will draw a large amount of the 30 amp service to bulk charge. So I wait for a half an hour until the charger drops to an accept level before turning on any big appliances to avoid tripping the main breaker. Not a problem with the Genset running while on the hook, as it puts out 60 amps.
Likes: tfox2069
Jun 1, 2009
1,860
Hunter 49 toronto
No. 30A
Whatever you do, DON’T do this on the 36.
I’ve just poured over the schematics , (there is an error), and completely understand how they work.
Here is a summary.
You have 2 panel breakers
Shore 1 & Shore 2
Both are basically hard wired as that shore 1 is wired to the “boat services” such as inverter, water tank etc, and shore 2 is wired to the airco feed.
Then you have the genset.
It is wired to an external 2-way switch, that feeds leg 1 from either the leg1 shore input, or the generator,.
The reason there are 2 different breakers is because the genset is rated at 40A, but shore is only 30A
The parallel switch then jumps the hot side of the line 2 breaker to the hot either the genset breaker or Line 1
So, to power both line 1 & line 2 from a single 30A boat feed
Plug in the line 1 cord
Turn on to shore
Turn on parallel
Turn on airco, which is being fed by parallel
Getting back to my VERY emphatic first statement
This boat is wired as single phase AC.
Meaning that the cycles of shore 1 & shore 2 are in exact phase with each other .
50A shore power uses 2 out of phase legs, that provide separate 30A independent feeds.
If you short phase 1 to phase 2, then you will let all the magic smoke out.
So, always plug your boat into 2 different 30A shore outlets .
Never use a 50A to twin 30A splitter on this boat
Apr 8, 2011
774
Hunter 40 Deale, MD
Here is a summary.
Shore 1 & Shore 2
Turn on to shore
Turn on parallel
So is this a wiring error on the part of Hunter? And what is the schematic error that you discovered? Would this apply to all boats attempting to connect two 30a to a 50a shore power via a splitter? I ask because I have exactly that splitter on my boat, as some of the newer marinas have slips with only a 50a power plug. I'm pretty sure, but couldn't swear I've used it for exactly that purpose, but now you have me concerned. I'm wondering why Marinco sells that hugely expensive splitter if it would fry your boat electrics - unless Hunter goofed on the wiring. Which...never mind. I know only enough about boat electrics to be dangerous, so don't take this post as questioning your conclusions - just want to understand more. Wondering if @Maine Sail has a thought here. I did look at the Marinco website and it has a fairly unclear description of the 50a splitter - wondering what the take on this is (the part about "similar or different power configurations" and the same text shows for the 125/250 volt Y adapter as well:
There is a difference between a 50A 125V system and 50A 125/250V. 50A 125V is still just three conductors, essentially the same as 30A but larger conductors. That’s still just single phase, so using a Y adapter should not be dangerous.
50A 125/250V does have 4 conductors, with two hot conductors out of phase. I can’t find anything showing how Y adapters for that are configured. If the adapter only uses one of the hot legs for both 30A hot lines then it should be fine. If it uses a separate hot leg for each 30A leg that would be dangerous.
Likes: plenny7
I’m also curious about this option of having both 30A circuits in parallel. If you connect a 30A cord to one receptacle and put the circuits in parallel is there any way to lock out the other receptacle? If not, would the male prongs on that side be exposed and carrying live 120V?
Nov 28, 2016
103
I am using a single 30A shore power receptacle, splitting it to 2 30A boat side inputs, and NOT paralleling. My boat does not have a generator, and the generator and paralleling breakers on the 120VAC panel are locked out, so I cannot see any issue, so long as my usage on board doesn't trip the shoreside bollard breaker, and it doesn't. Bollard breaker has been tested this year. My 120VAC loads are A/C when on, battery charger, water heater, and outlets and microwave as used. Fridge and freezer are both 12VDC only. Been doing it this way since earlier this year with no issues, even with A/C cycling on and off.
Jun 1, 2009
1,860
Hunter 49 toronto
I have just double checked with Marinco. They concur that the 2 phases from a 50 amp dock feed should not be joined.
On the schematic, the generator feed is unattached.
I’m going to assume they had an external shore-gen switch of some type.
On a side note, I suggest that owners of 49/50 boats with transformers check their 50A power inlets. Mine was wired wrong, along with 2 others I know of.
pm for more details
