The dipstick on the Hurth HBW 50 transmission (aka ZF 5 M) is an open ended metal tube inserted into a hole in the transmission fill plug.
When I changed the fluid today I discovered that the dipstick tube was coming loose from the plug. I gave it a little pull and it came out of the plug. I guess I'm lucky it didn't just fall off into the transmission. I have read a couple of accounts of this happening.
For the time being I put the prescribed amount of fluid into the transmission and put the plug back in (without the dipstick tube).
So I now don't have a way to check the fluid level.
I haven't been able to find any replacements on the internet. Does anyone have a source for these?
I don't know anything about welding and don't know if the tube and plug are compatible materials to be welded but I was thinking that might be a solution. My problem there is I don't know how far the tube should be inserted into the plug to get the correct depth for indicating proper fluid level (The tube inserts about 11/16 inch into the plug before bottoming out). If anyone out there has an Hurth HBW 50 transmission and plans to check their transmission fluid level in the near future maybe you could do me a favor and measure the length of the dipstick tube from the bottom end to where it enters the plug.
Any thoughts about this are appreciated.
And... check those tubes when you pull the fill plugs to make sure they are secure. I can imagine one dropping into the transmission could cause quite some damage.
