A sea trial, earlier this week, on a 2006 Beneteau 423 revealed a Volvo Pentax engine / prop shaft vibration. Even at a moderate 1500 rpm I could see significant visual deflection of the shaft when under way as I was inspecting the engine back side compartment. The vibration can also be felt in the cockpit and increases with significant intensity up to 2900 rpm, where I would called it severe. The obvious vibration is what pushed me and the surveyor to check further while underway with the engine.
The sea trial was done after the haul out inspection. No lateral shaft movement was felt when the propeller and shaft was inspected while on the hard before splashing back in for the sea trial.
I am several hundred miles from the boat and a subsequent inspection done by the "broker/mechanic" did not show any alignment issues between the engine and shaft coupling. He suspects a shaft and/or propeller issue.
The vessel has a 3 blade fix propeller, see attached pictures.
This is the only major issue (other then some other medium and small stuff, which are normal for a 2006, that needs to be addressed) that is holding up the purchase process until the root cause of this vibration is identified and corrected.
Any feedback on the vibration issue would be greatly appreciated, as well as, any other recommendations as to shaft and propeller choice, if it they need to be replaced.
Richard
Richard
