Greetings friends!
I am seeking advice on a few issues with a 2007 Hunter 25 I recently purchased. I have the boat on the trailer while preparing for barrier coat and bottom paint, and fixing a dragged rudder and bow eye in bad shape. Previous owner dragged the rudder a few times, along with never putting a block behind the backing plate of the bow eye, unfortunately it obviously had been tied to the dock from the bow eye in bad weather
, the U-bolt and backing plate wedged towards starboard, bending the U-bolt and cracked the fiberglass and blew out the gelcoat. I'm busy repairing the fiberglass and will re drill the holes and replace the U-bolt. I have some questions which I'm seeking advice for, on a few other issues I feel need addressing before this lake boat meets the ocean for the first time.
There is a 4" strip of fiberglass in poor shape under the rub rail (impact related?), not sure if it's leaking water through it yet, but I don't want salt water to soak in and worsen it. I'm dying to get out sailing, but this looks like its spongy and could get worse. I would have to pull the rub rail off to fix it properly, I'm wondering if I could just seal it with silicone for now, and fix it properly during the winter while in indoor storage.
Next one is with the anchor roller, shouldn't there be a back plate fastened with washers and nuts? Looks too tight of spacing for 3, but could fit 2 for sure.
And finally (for now
), one of the bolts on the pulpit was inadequately supported and the washer and nut pulled right through one side of the fiberglass, seems like it should have been a longer bolt with a block or plate supporting the nut and a larger washer? Not sure if this is shoddy work from the factory? Has anyone else had this issue and properly fixed it? Perhaps another job for winter storage? It's been sealed from the inside it seems, but if left as is for now, should certainly have sealant on the exterior as well.
Thanks in advance for anyone who spends the time to read and reply. I've worked on lots of boats, but this is the first one I've ever owned, I bought it a few weekends ago and am super excited to get it in the water! Thanks again for your time!
, the U-bolt and backing plate wedged towards starboard, bending the U-bolt and cracked the fiberglass and blew out the gelcoat. I'm busy repairing the fiberglass and will re drill the holes and replace the U-bolt. I have some questions which I'm seeking advice for, on a few other issues I feel need addressing before this lake boat meets the ocean for the first time.There is a 4" strip of fiberglass in poor shape under the rub rail (impact related?), not sure if it's leaking water through it yet, but I don't want salt water to soak in and worsen it. I'm dying to get out sailing, but this looks like its spongy and could get worse. I would have to pull the rub rail off to fix it properly, I'm wondering if I could just seal it with silicone for now, and fix it properly during the winter while in indoor storage.
