Has anyone done repair on the gate valve on the galley sink? The valve may be original to the boat.
I closed then reopened the value to after replacing the water heater and the now the gate stopper will not seat to seal. I know a haul out is the best way to replace the thru hull but there is no haul out on the lake as the shop that did my last haul out closed. The thru hull is below the water line so there is pressure forcing water up thru the value.
Just checking to see if anyone had any ideas of a temporary solution.
Thanks
Thanks
