Last weekend I pulled up the cabin sole it the aft cabin for routine maintenance and cleaning and found only 2 of the 4 bolts holding the transmission output flange to the prop shaft were still there. I found both bolts, one had sheared the other was undamaged so possibly backed out. Prior to this we had run from Key West to Hilton Head under sail, power, and combination without noticing any issues, including unusual vibration.
1) What transmission is on this boat? (can't find in the Hunter manual)
2) Any ideas what might cause this?
3) What is a suitable replacement bolt allow? 316 ok?
