I hoisted the spinnaker that came with my Cal 27 today in near zero wind with the tack tied to the anchor roller and a loop around the furler. The sail is about 5' off the deck at the tack.
Does this look reasonable for when there is some wind? The bag says it's a 0.75 oz. so what kind of wind range should I consider hoisting this in?
Do I really need something like the ATN Tacker or a loop of line with parrel beads around the furled genoa ? It does not seem like I'm going to be moving the tack up and down, or are those for allowing the loop to move more easily when I jibe the spinnaker around the front of the headstay?
Is the sail size roughly the (SL 31.4 x the SF 19.4) / 2 or 300 sq ft? SMG & SMW are the luff/leach I think.
Seems like I should start looking for a used snuffer to make using this single handed a bit easier.
Thoughts?
Thoughts?
