Replace Toilet Hose on 92 H30
Feb 25, 2014
69
Hunter Hunter 30 Lake Lanier
I need to replace the hose from the toilet to the holding tank on my 1992 Hunter 30. Would like to know how painful this process will be. I know I will need to remove the batteries to get access to the holding tank. What other joys will I find getting into cramped areas?
Replaced my hose on a Cal 27 and had to cut a new hole in the bulkhead, as the hose would not bend as it did when the boat was built.
Cheers and hope everyone is have a good sailing summer.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Replace it with Raritan Saniflex. Pricey, but much easier to thread. I used a messenger line when I replace the hose between the hand pump and thru hull.
Dec 2, 1997
9,011
- - LIttle Rock
If one hose needs replacing, you'd be smart to replace all the hoses at the same time. 'cuz if one needs to be replaced, they all do. I second Justin's recommendation that you use Raritan SaniFlex hose RaritanSaniFlex hose if you only want to do this job ONCE instead of every few years. It's the top rated hose because it's proven to be proven to be100% odor permeation resistant--even has a 10 yr warranty against it--and has the added advantage of being so flexible it can be bent almost as tight as hairpin without kinking, making most re-hosing jobs a LOT easier. If your toilet has a 1" discharge, replace the discharge fitting with one that can use either 1" or 1.5" and use 1.5", which is the size of the fittings on your holding tank. Your toilet mfr should supply one for free or least close to it.
And as long as you're replacing hoses, this would be a good time to replace your toilet's joker valve, which should be replaced annually but I'll bet money it hasn't been replaced in years.
Don't be spooked by the SaniFlex list price.Defender has it for about $10/ft. Use it for your toilet discharge line, pumpout line, and any macerator pump plumbing. You can use Shields or Trident flex PVC #148 for your toilet intake line and vent line.
--Peggie
Before breaking out the Sawsall and bulkhead destruction, I would cut the hose into small parts and remove it in pieces. I would try to make sure there was nothing in the hose before I started to chop and dice it up.
Jul 7, 2004
8,542
Is your tank metal or plastic? Mine is metal. You may need to rescope the project. After all that work you want a plastic tank. And then a SCAD tank monitor........
Dec 2, 1997
9,011
- - LIttle Rock
There's no way to guarantee dry hoses and the last thing he needs is drips that are sure to stink later! Besides...he'd still have to gain access to the tank to disconnect the old hoses and connect the new ones. Better to connect new hose to old using a male-male connector, (use PVC cement or other "glue" to secure the hose to the connector) and pull them through.
--Peggie
I agree with the concept.
The OP say the hoses are not removable and that he would need to destroy the bulkhead to get the hose out.
That seems a bit extreme.
Dec 2, 1997
9,011
- - LIttle Rock
It shouldn't be necessary to destroy a bulkhead to gain access to what's behind it. Doesn't sound like the OP was any more knowledgeable about how to do that than you are and just gave up on replacing hoses. None of us were born knowing everything-- anything really--about how to maintain and repair stuff on a boat...even after 30+ years my own learning curve is still active. Trust me, it IS do-able...you just need to know how. Get some advice from a pro who's had to deal with similar issues and knows which fasteners to remove to open up a bulkhead without damage. Or, if there's a Cal owners page on FB, someone on it may be able to help.
--Peggie
Likes: Justin_NSA
Hunter 30_88-94 Ipswich, Ma MA
If you’re only replacing the hose, it’s really not too bad. Yes, you’ll have to remove the batteries, and maybe remove the platform they sit on to get to the tank.
The access from the toilet under the aft birth shouldn’t be a problem. Just remove the access panels and you’ll have enough room to snake the hose thru and into the aft locker where the tank is locate.
If it’s the original tank, it’s metal. While you have everything open, be sure to take a good look at the tank to see what condition it’s in, especially around the fitting where all the hoses attach.
I replaced my holding tank several years ago, but that’s a whole other saga.
Feb 25, 2014
69
Thanks for all the comments. I will need to review the tank, once I get to it. As temperatures down south have risen, I think this will be a good fall project.
Cheers everyone.
