Hi,
I replaced my sanitation line recently (2009 Hunter 36). It was pretty straightforward. I have a jabsco electric toilet. It has a one inch very flexible line that exits the head. It is about 10 inches long. It connects to the standard white 1.5 inch sanitation line using a "reducer" plastic fitting, which then connects to the holding tank.
I made all the connections and clamped them tight. It was a "one for one" swap - as in I simply replaced the line exactly as it was before. Now when I do test flushes, I hear air leaking out of the connection between the two hoses, and small amounts of water drip out. If I undo that connection, I get a lot of water flow back up the hose. I have clamped very tight, but have not used any sealant, glue or similar.
When I remove the connection at the holding tank and flush, some water is pushed out of the end of the hose, and it is brand new, so obviously it isn't block. The toilet does empty properly and I am not getting backflow into the head. I have tried leaving the pump out cap off and also cleaning the vent, so I don't believe there is a vacuum being created in the holding tank.
However, I can't seal the connection, and it concerns me that there is so much pressure in my line. Is this normal? Is it just the weight of water in the line that is causing this back pressure?
Any help appreciated.
