Emergency bilge pumps(s)
Aug 19, 2021
511
Hunter 280 White House Cove Marina
Quick and easy.
How often do you test yours? Annually? Semi Annually kind of a spring fall thing?
Or
Do you just hope and pray it works when you need it?
Aug 19, 2021
511
I would test it more often than annually or semi annually. And it's common to need to replace the diaphragm from time to time since they can dry out.
I was thinking the same thing. I am thinking quarterly.
I am also thinking if you need it and it does not work, that would be a bad thing.
Aug 19, 2021
511
I'm thinking that if you need it... that is a bad thing... and if it does not work that is a catastrophy. :yikes:
I am right there with you brother.
I am thinking with a used boat, who knows when it was last tested.
I am also pondering the method of testing. Disable the auto bilge pump. Pour 5 or 10 gallons of water into the bilge and give it a whirl.
If that does not work, hook up the bilge pump and make a plan for repairing the other.
May 24, 2004
7,224
CC 30 South Florida
I would test it immediately and then on a semi-annual schedule. When we took delivery of an h320 years ago we waited 6 months to test the manual bilge pump and it was then we found out the pump casing had been cracked during the boat production. Never underestimate carrying a couple of buckets and if you have the electrical power having a 120V Sump pump.
Aug 19, 2021
511
I carry a food grade bucket that I coil my freshwater hose into.
I am having no issues with my standard 12v bilge pump, other than I am sure I just jinxed myself.
Basically it is one of the ex-navy thing and everything needs to have planned maintenance system and a planned maintenance schedule.
