Heater
Oct 10, 2010
269
Hunter H260 Gull Lake
On my new to me Hunter 29.5, I’m curious how long it takes for the engine to run in order to get enough hot water for the furnace to work? Also how long before it blows heat and how long would it heat for?
I’m assuming on anchor that’s a battery killer.
Thank you.
RC
Jan 4, 2006
7,870
Do you not have a diesel fired heater to supply antifreeze hot water to the heating circuit ? To heat the boat by engine generated hot water alone would be extremely inefficient.
Not really as the alternator is running to take care of the batteries, however, it is an engine killer.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
I doubt a 26-footer has a hot-water heater system…. And if you did, you would normally have a separate diesel fired heater for it…not the engine.
The engine may have a heating loop to the water heater, which is do;ve Kent way to have hot water for washing on anchor… this is a pretty common setup. Cabin heater, not so much. It doesn’t take long to get my 6-gallon water heater HOT Using the engine.
Do you have photos of the heater system? Heat vents? Anything to help us understand what you have?
Apr 5, 2009
3,333
If you are talking about an engine heated "red-dot" system it will only work when the engine is running so battery use is not an issue and it will quit putting out heat shortly after the engine is shut down.
If you are talking about a diesel fired burner that heats water, you do not need to run the engine at all and the battery use will depend on what you have on your system.
I have an Espar hydronic system and it takes about 5 minutes to start putting out heat and uses 10 amps on high burn and all fans but most of the time it will average less than 1/4 of that.
