Finally had a sunny weekend and had the chance to get the deck organizers and cam cleats installed in my 1984 Cat 22. I got the instructional video from CD and probably watched the steps about 5-6 times. It went mostly well, but one thing that wasn't called out specifically in the videos ended up becoming an issue that required me to get new bolts for all organizers and cam cleats. Here's what it looked like after I drilled the holes and glued everything in place:
![IMG_2766.jpeg](/data/attachments/183/183560-6a3d813ba293ec799f566fca690da4a8.jpg)
And the view of the bolts from below:
![IMG_2767.jpeg](/data/attachments/183/183561-057354d58fde7c6c283fc895d70efc19.jpg)
Now, a couple things: I did get two bolt lengths. The shorter of the two was way to short to get the lock nut, bolt and locking bolt in place, so I knew that I had to use the long one and was going to have to use a hacksaw to cut these shorter.
In the video, it goes from drilling and fitting, then to using the hacksaw. It also mentions that you glue this down in place and let the bolts hold it in place to harden overnight. What it did not clarify explicitly is that you must use the hacksaw to file the bolts down before you glue them in. Ouch.
Even while I was doing it, I kept asking myself, "Isn't this gonna get glue in these threads? I hope I'll be able to file these down afterwards."
Sure enough, the next morning, when I pulled the bolts out, the threads were all covered in glue. I tried soaking them in mineral spirits and using a plastic then a brass brush to get all the glue out of the threads, but it was a hopeless attempt. Fortunately, the hardware store had the same bolts in the sizes that I need - even an in between length that didn't require the use of a hacksaw.
So to summarize if you're doing this project:
![Face Palm :facepalm: :facepalm:](/styles/flatawesome/xenforo/smilies/facepalm.png)
Fortunately I was doing all this in town, and not all the way out at the marina.
- Drill your holes and put the bolts through and measure them for trimming
- Take the bolts out and saw them to length
- THEN re-insert and set the glue
