H280 - Pulling a New Outhull
Aug 19, 2021
511
Hunter 280 White House Cove Marina
After reviewing the drawings (below) for my boom, I figured I could pull it just like a halyard.
First thing I encountered was, the boom is full of pine needles, features and three eggs. I think there is more in there i just could not reach it with my old school wire hanger I straighten out.
One it get the bird debris removed do you have any tips and tricks for pulling the new on thru?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Similar issue on my Hunter 386 after 3 years on the hard adjacent to farms. Took a while to remove the bird nest and eggs from the boom.
Suggest using a small diameter tag line to snake it through then attach new outhaul and pull through.
6,017
Oday 322 East Chicago, IN
Are there any lines run through the boom now? If so, tie a messenger line to the end of one, pull that line (and the messenger) to the mast end of the boom. Then secure the new line to the old line and messenger, and pull the bundle back through the boom using the messenger.
Or you could try a really long stick pushed through the boom (if you can get past the birds nests), tape the line to the end of the stick and pull it back through. May be difficult with the boom caps in place.
Aug 19, 2021
511
Similar issue on my Hunter 386 after 3 years on the had adjacent to farms. Took a while to remove the bird nest and eggs from the boom.
Suggest using a small diameter tag line to snake it through then attach new outhaul and pull rhrough.
I was thinking my next step was a garden hose enema to flush the boom. I will definitely use a smaller tag line for the initial pull.
Likes: Tally Ho
Aug 19, 2021
511
All the lines are there. The outhaul was damaged when my head sail unfurled in January. I have new first, second reefs and outhaul on hand. I just need to clear the boom.
Your idea of a long stick made me ponder if a stick(s) of PCV would work. Hmmmm?
I am really open to trying anything and everything other than dropping the boom.
Jan 7, 2011
6,017
Yes, the hose enema, and a long stick or pvc rod to help push the junk out should work…then, if you can get the stick pushed all the way through, tape the new lines to it and pull them through. But I also think if the old reef lines are in the boom, you could use those as messenger lines To pull the new ones through. Not sure (don’t remember) if there is other stuff (blocks) in the boom…I don’t recall seeing them on my H280.
Last resort.... drill out the rivets on the end cap. Clean out and drop lines through.. then rivet it back on.
Aug 19, 2021
511
The hose enema was completed yesterday. I swear there was 1/4 a bale of pine straw in there, some unidentifiable bird parts and three nasty bird eggs. What a mess.
The diagram show a fixed block and traveling sheave. It seems a little bizarre to stuff the first and second reef, the outhaul block and sheave in there and the only access is the end cap. SMH. What could possibly go wrong?
Looking like a rain out this evening. More to follow.
Thx for all the help.
Aug 19, 2021
511
I finished this project this weekend. I did not have to use plan B, Thank God.
Thank you for your assistance and guidance.
Likes: rgranger
Aug 19, 2021
511
Good on you.
how did you get the lines pulled Through?
Once I cleaned everything out of the boom. I sewed the new outhaul onto the old one. I pulled the traveling sheave from the mast using the outhaul that goes between the sail and the traveling sheave.
There was so much "stuff" packed into the boom that the "stuff" was chaffing the outer case of the lines. I will post pictures later today.
Likes: Tally Ho
