Perhaps this should be in the Trailer Sailors subforum, but electrical questions are often best addressed here in @Maine Sail's forum.
I'm thinking about how to charge our boat's battery bank from a tow vehicle. We have a small compressor cooler / freezer that keeps our ice packs (and ice cream) cold. No problem on a short tow, but on a long trip - or, as happened last year, an unexpected multiday delay - we could arrive at a launch with empty batteries.
Q1: Is something like the Victron Orion battery-to-battery charger appropriate for this application?
Running power directly from the truck to the boat bank seems bad because:
(And of course they apply appropriate 3-stage BULK / ABSORB / FLOAT charging).
So, if I installed a DC-DC charger:
Q2: Can the 18A Victron (their smallest model) be programmed to a lower output current? If not, is there a reliable alternate brand that can be?
The easy solution is just to pull power from the auxiliary 12v line on the 7-pin trailer plug. But that aux line won't have 18A available, and would blow a fuse in the truck (my AGMs would happily take 18A of current in BULK - when discharged to ~60%, they'll take the full 40A from our shore-power charger). I don't really need an 18A charge rate - 4-8A would be sufficient (it only matters on a long tow anyway, in which case we have plenty of time to charge at a lower rate).
Q3: Perhaps a crazy question: a theoretical alternate approach would be to install a 500w inverter in the truck and run 110v from there to the boat's shore-power input. Is this a good or terrible option?
The 40A shore-power charger would max out at ~4-5A input (@110v), so any decent extension cord would be sufficient (no need to route 10 AWG boat cable). A good 500w pure-sine-wave inverter is about the same price as the DC-DC charger. And I'm sure 110v would see some other usage in the truck if we had it available (whereas the DC-DC charger is single-use-only). Running AC power from truck to trailer seems just a little crazy, but it would theoretically work (yes, cable routing to avoid chafe would be really important!)
- The voltage drop over a long cable might reduce the voltage below that needed to actually charge. 40' of 10 AWG (round-trip of 80') drops .96v. (40' seems like a lot, but routed from the front of the truck, through the chassis to the hitch, along the trailer and up to the cockpit, it's probably pretty close)
- If we did get adequate charge voltage to the boat batteries, we'd have no overcharge protection
