Edson brake install!
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
Good morning my fellow fortunate Hunter owners!
You all have the privilege of reading my rantings and ravings as I replace a wheel brake that was mysteriously removed for some reason from my pedestal to compound the problem they also routed the data cable for the auto pilot through the hole meant for the pedestal break.image.jpg
May 27, 2004
2,059
Don't know what year your Hunter is but the wheel brake was an option when sold new and it may never have been installed.
When I put one in 30 years ago, I don't remember it being a terribly hard project.
So, good luck and post your results.
G.
Likes: Growl
Growl
Oct 11, 2020
109
I thought they were stupid expensive also until I ducked down to grab my cell phone and coming back up to see three sterns with kicked out outboards, I pushed all three of them boats all the way forward with no damage to mine, I still can’t believe it and consider myself very fortunate so whether it came with it or not it’s getting one now my brothers.
Growl
Oct 11, 2020
109
I still haven’t got down there yet today. Lol
I suspect you solved your own mystery there. I’d bet the PO figured they could just use the autopilot to hold the wheel steady when they needed to. Not my first choice, but I could see how someone would think it was a good idea, especially if the brake had already worn out.
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
My H33.5 doesn't have one installed either. Would be nice though. ~$300 USD
Growl
Oct 11, 2020
109
I was surprised they didn’t come standard!
$300 worth every penny!
Growl
Oct 11, 2020
109
Good Day,
Started project today, compass came off easy, 3 screws, snipped wires etc.
I broke the compass case as was expected after it weathering 30 years of UV rays. So I ordered a new Compass case and a new to me Ritchie compass. I’m still trying to figure out where to drill the Auto Pilot cable and it has a big end fitting. I don’t want to drill a hole that big in my aluminum post/pedestal!
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Oh, too bad about the compass! So, can you take the connector off the cable?
Growl
Oct 11, 2020
109
The compass case broke, it was cracked and needed replacement, I’m looking at a newer Richie or any suggestions?
First thing I lost was my ratchet driven Phillips went right down the pedestal have no idea where it went, lol it’ll probably come rolling out when I get some High waves!
I don’t know the AP looks like a factory made fitting I’m gonna have to find someway to make it smaller.
May 19, 2020
85
Hunter 30-2 Quincy
If you can access the route your AP cable takes it would be far easier to disconnect it from the control module, tape a pull string to it, then pull it all the way through your pedestal. To reinstall just do the reverse. The end that attaches to the control module is just bare wires
Growl
Oct 11, 2020
109
Ha ha, I knew someone was going to say that. I was just laying here thinking I’ll drill a big hole and then goober a bunch of silicone in it after I’ve pulled the cable through. Lol! Do I also need to remove the throttle armature to provide room for the brakes?! I’ve also noticed there’s grease on everything should I clean off the drum that the brakes right on?
Growl
Oct 11, 2020
109
I still have no idea where the Phillips socket went???
May 19, 2020
85
Hunter 30-2 Quincy
Not sure about the throttle but yes you should absolutely clean the surface the brake shoes ride on. Sounds like someone was overzealous with the lube for the chain
If you drill a big hole and silicone it it's gonna look like a hack job.... very similar to much of the work done on my boat by its previous owners
Growl
Oct 11, 2020
109
Yep, I know, thanks for talking sense into me,
but, Every time I turn something breaks or needs replaced!! Do I also need to replace the chain and cable like Edson recommends after 10 years?
May 27, 2004
2,059
The pedestal sits on the cockpit floor. The floor has holes in it to allow cables to pass through.
Get a shop magnet on a wand (Auto Zone, etc.) put the magnet in one of the holes from the under side and, if you're lucky, the socket can be coaxed out.
Likes: Growl
Growl
Oct 11, 2020
109
I wish I would’ve checked this post earlier I just lost two magnets! Gosh darn it!
Growl
Oct 11, 2020
109
I’m having a terrible time finding the auto pilot cable I don’t even know how they got it through the hole that’s meant for the side break but they did it’s a mystery to me and I don’t know what to do next laugh my ass off
