I have been reading through the Selden Furling Mast Manual and I noted that it specifically indicates that the sail is to be furled onto the starboard side of the furler extrusion (with the extrusion rotating counterclockwise looking down from the top). It also says that the furling winch mounted on the mast must be turned clockwise when furling in the main.
On my 41DS, the main is wrapped the opposite way probably due to the fact that the two clutches for the furline line are marked "I" on the left and "O" on the right. Pulling on the "I" side furls in the sail but does so on the wrong side of the furline extrusion because it turns the winch hub counterclockwise..
Can someone with a Selden main furler confirm which way their main is furled and which furler line (left or right) they use to furl in?
