I purchased a hot/cold mixing valve from Fishermans and plan on incorporating it into my hot water system, but it did not come with any info-sheet showing how it should be connected to the hot and cold lines.
Has anyone installed one of these and clarify for me the plumbing connections.
I assume the inputs are the two threaded inputs on the body and the mixed water comes out the bottom. Assuming that is correct, does it matter which side is HOT ?
Thanks,
Thanks,
