Need some advice. My cat 22 has vc17 on the bottom and seems to have many layers of paint, it is also flaking/pitting in places. I’ve been sanding for hours with wet 60 grit paper which is very slow going, acetone didn’t seem to do much other than smear it. I see gel coat in places and what I assume is a primer - I’m hoping I’m not setting myself up for failure sanding so much but the vc17 was applied over pits and cracks. Had been told I need to completely sand every spec of copper off which in some cases is taking it down into get coat because of the pits. Does that sound right? After that should I go back over with something like 220 grit?
The local shop said to use marine-Tex to fill the cracks followed by primer inter protect 2001e followed by Micron CF. I’m not sure of this advice because the guy was really confused by the word keel… shouldn’t I be able to use gel coat to just smooth the bottom pits? I’m not sure on the other products he mentioned.
