ignition key cover Catalina 30 1978 vintage
mrreg
Jun 16, 2014
19
Catalina 30 8087 Alameda, CA
Anyone have a good solution to building or purchasing an ignition key cover for the side mounted control dials and ignition key
for a Catalina 30 1978? The cover would prevent skipper and passengers from kicking a breaking the ignition key that sticks out into the cockpit area.
Thanks.
Russ Grant
russgrant43@gmail.com
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
A photo would help those who don't own a Catalina 30 or if the design changed over the years. I would assume aryclic sheet would work without seeing the controls.
mrreg
Jun 16, 2014
19
Thanks for the response. Here are a couple of photos. Once the key is in the ignition, it stick out into the cockpit area at leg level
782
Catalina 387 Dana Point
1. Hinge a piece of plexi from the top (commercial unit shown, easy enough to DIY):
2. Replace with a new panel that already has a piece of plexi hinged at the top:
(This is what was done to my C-30 by a P.O. )
3. Remove the keyswitch and replace with an On/Off switch and a start button. Now you have newfangled keyless starting. After the keyswitch that was installed in the replacement panel failed, I made this mod to my C-30. No more lost keys.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
I have a similarly recessed / exposed panel and have not had a problem in 20 years.
If it worries you I suppose you could just hacksaw off the overhanging outer end of the key so it didn't stick out as much.
mrreg
Jun 16, 2014
19
Thanks to all who replied. Great suggestions. Definitely an doable diy project
Russ
