Add midship cleat to Vision 32?
Aug 21, 2019
41
Hunter Vision 32 Shilshole Bay Marina
Hello forum friends!
I would like to add midship cleats to both side-decks of my Vision 32 to aid in docking, especially solo, since I don't have a lot of room for error in my 34' slip. From a physics standpoint, based upon what I have researched in other forums, I understand the cleat should be positioned perhaps just aft of the midship stanchion, such that taking up tension on a fairly led spring line upon entering the slip acts to kick the stern in towards the dock, it anything, rather than pulling the bow in. The problem, of course, is access. To properly mount a through-bolted, backed, sealed cleat on the side-deck means being able to access the underside of the deck, but on V32s (and other Hunters, I imagine), there is a molded fiberglass liner in the way, with varying degrees of dead space between it and the deck, depending on where you knock on the liner. A PO installed (properly) a low profile windlass on the foredeck, and hole-sawed through the molded headliner to back those bolts with giant washers, so I know it's possible. I'm just wondering if anyone else has undertaken this specific project before, and can offer some advice?
Many thanks!
-Kevin (S/V Endolyne, Seattle)
Rick D
Jun 14, 2008
7,207
That would be very difficult and hacking away at the interior won't help with subsequent buyers. I would just tend to get more accustomed to it. She is a very maneuverable boat. Maybe spring lines from the bow or stern to the dock's mid cleat? Maybe leave a set of dock lines on the dock permanently and have a traveling set aboard? (I do and that's a big help.) Good luck whatever you decide!
Aug 21, 2019
41
Fortunately, the parts I believe I'd have to hack away are out of sight, tucked up into the cubbies amidships. I agree that she is maneuverable, but *unfortunately* my engine isn't the most reliable 3GM30 in the world right now. In fact, she stalled out on me 3 times coming into that much shorter slip (ALWAYS when it counts most, eh?), and I would've been screwed if I hadn't hedged my bet by bringing a few excellent crew along to help in the delivery. I do as you do in terms of traveling and permanent mooring line arrangements, but dock cleat position, slip length, and even my dinghy storage location just behind the dock box, are all factors working against a smooth docking evolution. All that to say: having the extra cleats installed would be a *major* improvement to the safety of docking operations, in my home slip and in slips unknown, and would certainly put my (relatively new-to-boating) girlfriend's mind at ease, and mine as well.
Apex
Jun 19, 2013
1,229
C&C 30 Elk Rapids
They have cleats that mount to jib tracks. Not sure the runing gear layout of a vision 32, but perhaps an acceptable solution?
I have a mid-ship cleat on my present boat and love it. Can't give advice on your install but I can say that if you do it right... you will find that they are very useful.
In addition to helping you get in and out of the slip, I like the way you can rig spring lines that keep you stationary w.r.t. the dock. I makes stepping on and off feel a lot more secure.
This is how I tie mine
If you decide to do something similar, make sure the mid-ship cleat is large enough to accomodate two dock lines.
Please post pics of the instal.
Aug 21, 2019
41
The tracks are inboard on the Vision 32 and 36. It's just a toe-rail on the gunwale. If only I had a Catalina 27!
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
I have a midship cleat on my O’Day 322, but I don’t use that for docking.
Instead, I have a line with a loop, cleated on the dock, and on a hook at the dock. When I come back to the slip, most often single-handed, all I have to do is reach over and grab the loop, and throw it over my cabintop winch. Then, even in a strong crosswind blowing me off my finger pier, all I have to do is put the boat in FWD, give her a little throttle, and she snugs right up to the finger pier. I leave her in gear while I throw on the bowlines, sternlines. The I slip the tranny in N and go back and slip on the spring lines.
Getting a line on the midship cleat would be way harder (and almost impossible if single-handed).
As Far as access is concerned, on my O’Day 32, also with a hard liner, I can reach the stanchion thru-bolts, and the cleat thru-bolts from the gap between the hull and the liner. Not a big gap, but enough I can get a wrench up in there. Sometimes I have used a mirror to see up in the gap…or my phone camera.
In this photo, if you follow the hull up my the arrow, there is a gap between the liner (with the wood trim) and the gray hull wall. In the cabinets, the same gap exists so I can reach all of the stanchion base thru bolts.
Jan 7, 2011
6,017
DArcy
Feb 11, 2017
1,789
Islander Freeport 36 Ottawa
Depending on your dock arrangement you could use a stern bridle. I use this arrangement for docking and it is incredible how well it works. I have the loop (part over the dock cleat in this illustration) ready to go and just drop it over the dock cleat then pull in on the tail around the winch. Once the slack is out of the line I put the engine in forward and turn the helm away from the dock. The boat just sidles up to the dock, even in a cross wind blowing me off. Don't take any turns around the cleat, the line needs to be able to slide. I can do this all from the cockpit on my boat. The problem is when there is someone on the dock that wants to help and puts turns around the cleat.
You mentioned engine troubles, if the engine dies, just pull in a bit tighter and you won't go far.
I don't have a toe rail or outboard tracks. My springline cleats are on my inboard jib sheet tracks, just forward of the first jib sheet fairlead. Been working fine for 25 years.
Here are some other ideas:
Single Handing 101.1 Midship Cleats Pictures Midship cleat PHOTOS / Flix
Single Handing 101.2 HOPPING OFF THE BOAT IS UNNECESSARY
Single handing & Bull Rails
41
The jib tracks on a Vision are mounted fairly far forward, as headsail is not a full genoa, but merely a 90-100%er, and Hunter didn't think that warranted beefy standing rigging. Indeed, the sheets are meant to lead aft from the car through a series of fairleads to the winches (not a great design in my opinion, and a PO rigged it otherwise on my boat). Given that, there is no good way to make sure a spring line is led fair of the stanchions in a docking situation on this vessel. Thanks for the additional references! I actually read those prior to posting here, and the 8" pop-up cleat in the first ref is similar to what I'm looking for.
Aug 21, 2019
41
This is pretty close to what I had in mind!! And I should've been more clear in my original post that I never intended to bullseye a mooring fit from the midship cleat (@Tally Ho ), but rather rig a lasso to catch the aft-most dock cleat, arresting my forward motion to "buy myself more headway" in case things went sideways. From that point, it's easy to walk the boat forward and attach the permanent mooring lines I've rigged up. The stern cleats on the Vision 32 are mounted quite far aft, and were I to snag the aft-most dock cleat using the stern cleat only, I'd still crunch the dock. Maybe utilizing the headsail winches as you've shown here is a good alternative to mounting more deck hardware? I have a good bit of windage and about 11,000 lbs displacement - do you think the method you're showing here would safely handle those loads, without harming the winch?
Likes: DArcy
RoyS
Jun 3, 2012
1,742
Regarding your original plan: if the ceiling liner is fiberglass, purchase white plastic plugs for, say, 2" holes. Drill down through your deck and liner with a feeler (long, small diameter) bit where you want to mount your new cleat. Drill up into your liner with a 2" hole saw using the feeler bit holes as the centers. Now you can drill down with the correct cleat fastener size hole. Through the 2" holes in your liner you can install a backing plate or large washers and nuts. The plastic plugs should snap into place on the liner covering the nuts. Worst case, the fasteners will remain uncovered and protrude through the liner. Paint them white if that is the case. The feeler bit gives you the opportunity to determine if this plan will work before you drill any of the larger holes. If you determine that you cannot use your feeler bit hole location it is easy to epoxy the small hole and try something else. Mcmaster Carr should have some kind of suitable plastic hole plugs.
Likes: Dalliance
Cannot speak to the Vision and modification technique. I can suggest the mid-cleat I installed. When not in use it is out of the way of feet and toes walking the deck. When needed easily pops up to give the needed boat control of a mid-ships spring line.
:plus: on @DArcy 's technique for docking. I have used the same for years. I use the mid ship cleat as I am a bit lazy walking to the bow to attach the docking line.
Works the same way in all sorts of conditions. Just need to convince the helpers on the dock, "All that is needed is to just drop the line over the dock cleat." When they see it work there have been some pretty wide eyed expressions.... "You mean my wife doesn't have to jump to the dock any more?"
Likes: Dalliance
DArcy
Feb 11, 2017
1,789
My boat is very optimistically 17,000 lbs dry, probably over 20,000lbs currently and, with high freeboard and a deck saloon cabin, has quite a bit of windage. I have never had any concern that the winch cannot take the load. The winch can probably take a lot more load than a jib car track that people above have been using for a midship cleat. I actually use my jib car as a turning block to line up the aft part of the bridle but I am concerned with the side load on it so I plan to add a ring on the cap rail for the turning block. I wouldn't go straight to the winch from the dock cleat as you likely won't be able to align it properly and could get an over-ride. The winch is just for convenience, you could go straight to a cleat but will need to be able to pull in then cleat it quickly.
I like what @Tally Ho said about using the winch. I used to berth next to a guy who did that exact same thing and it worked very well for him. He kept a looped line on a cleat on the outer pilon of his slip. He would slip it over the winch and throttle in. The line kept him lined up.
Here is a good video showing the technique.
Where you bring the line back to the boat (i.e. the winch) is where the boat will stop along side the dock. If you have a dock cleat that is a foot or two short of the end and you need to stop the boat before you run the bow into the dock, you bring it back to the winch. If you have a long slip and no worries of crashing then bow you can bring the line in anywhere in the cockpit. Where you tie it to the boat is where the boat will stop.
Jan 7, 2011
6,017
I have watched that video before, but i don’t use that procedure because I don’t thinks it is that easy when single handed. If you notice on the intro clip, they are coming into the slip about like I do…but then 1 person goes to the side deck to throw the pile of rope on the cleat, WHILE a second person essentially stops the boat. Then they tighten the bridle to bring the boat alongside the dock.
I don’t think I have time to 1) step over to the side deck, drop the rope, then get back to the helm and stop the forward progress (probably would have hit the bow by then) Or 2) stop the boats forward progress (and in a crosswind I start sliding toward my neighbors big, expensive powerboat), get to the side deck, drop the pule of rope, get back to the winch and pull hard to get my boat back alongside my finger pier.
Plus, I have a line already cleated on that cleat, so not sure my bridle will necessarily catch on the cleat…note they always do this on an empty cleat.
I still like my loop on the Shepard’s hook at the end of my finger pier. Even while under power (idle usually, but in FWD), I can step to the side of my cockpit, grab the loop, and slip it over the cabin top winch. Then back to the helm to slow the boat down or whatever needs to be done to safely bring the boat to a stop alongside my pier.
If I have crew, they sit on the cabin top just at the gate opening. They can easily reach the loop as I bring the boat in alongside the pier and slip it over the winch. From there, I have it all under control from the helm.
The other advantage of this setup is that when I am in a strong cross breeze, and trying to leave the dock, I can put my loop over the winch, put the engine in gear and “balance” the boat alongside the pier. I can then remove all of my dock lines while the boat stays put. I return to the helm, take a deep breath and slip the tranny in REV and start backing out. I put the loop back on the Shepard’s hook as I am backing out, so it there when I come back in.
In the past, I was pretty unsure about going out in a North wind (crosswind for my slip, blowing me into my neighbors boat). With my loop and Shepard’s hook, I don’t think twice about it.
I will have to take a video of the process one of these days…it has changed my confidence greatly.
Jun 18, 2015
69
Mascot 28 Pilothouse Motorsailer Grand Manan
The "midship cleats" for single hand docking do not need to be amid ship. In fact,it is best if they are mounted adjacent to the cockpit fore bulkhead,where they can be reached easily from the cockpit. If you hang a fender just aft and another just fwd of this cleat,the bow nor stern cannot pivot away or towards dock more than a few degrees-as long as the midship line is snug and at aprox. a right angle to the dock and boat. The purpose of this midship line is to stop fwd/aft motion immediately,& hold the boat parallel,while you put proper lines out at your leisure. Cheers/Len
