Hello,
I have noticed some water loss from the weep hole so time to rebuild my Obendorfer pump. I believe it is a 202M-15 of late 80s vintage. I definitely need new seals and the carbon bearing has degraded at one end (engine) with a few chips of material missing. I have a couple of questions for the wise members of this group. Do I need to replace the bearing if only a few millimeters missing? I believe the shaft is well supported and shows no sign of wear. Also has anyone tried a workaround for the Obenforfer seals? Is there any reason why a conventional oil seal (x2) wouldn't do the job? I'm not sure if a seal of the right dimensions available but if it was is there any reason why it couldn't be deployed? The OEM seals seem stupidly expensive for what they are. I'm in Aus so I haven't attempted to source some OEM seals locally but I'm thinking they will be as dear as poison. Thoughts please. Cheers Kevin
