Brass? I thought brass was a no-no.Would you want stuff clogging up a strainer which is easily cleaned or a heat exchanger which isn’t…?
Once you figure out that answer, select between a number of good brass strainers - the cheap(er) plastic ones can break more easily and size it based on the GPH rating of the water pump. Bigger is better.
