I am trying to determine the size of the run capacitor needed for my Polar Bay AC SLW16DHS-1 on my 2005 Hunter 33.
The old capacitor is blown and the numbers are worn off by the goo that oozed out.
The only thing left on it that I can read is "E189613". That doesn't seem to help me in a google search.
The AC is 120V with a normal running amperage labeled at 13 amps. It has a separate start capacitor.
Does anyone happen to know what the MFD rating is? Or have an educated guess based on working on similar AC units?
In cooling mode it runs OK and does cool the boat, but draws about 19.4 amps in steady state, as opposed to the 13 amps that it is rated.
In heat mode, it runs OK for about a 30 seconds to a minute, while the amp draw steadily increases to around 30 amps,
where it either kicks itself off with a shudder or trips the 25 amp breaker.
