Tiller question
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
That's for either an autopilot or a strut to "lock" the tiller in position.
Are you familiar with tiller pilots?
8
Catilina 22 Lawrence
I do have a tiller clutch on the tiller! It will be the first to use the clutch. I do not see where to use the peg.
jviss
Feb 5, 2004
7,089
I'm not sure I understand that - can you be a bit more descriptive?
Mar 29, 2022
8
That was not my tiller I have the photo of. only different is the Tiller clutch on the bottom forward of the pin. See the photo from earlier of the pin.
Sep 30, 2013
3,584
That's a "tiller pin" for a Raymarine tiller pilot, ST-1000 or ST-2000.
Aug 2, 2009
651
Catalina 315 Muskegon
There should be a corresponding bit of hardware somewhere in the cockpit to secure the other end of the autopilot. Assuming the tiller isn't from another boat.
Jun 1, 2004
8,163
I completely do not understand your comments. Perhaps a little rephrasing might help.
Anyway, if the pin is for a tiller pilot there will be other connections nearby that are needed for it to work. If it's for a "tiller tamer" or some type of mechanical locking device there will still be some connections... small cleats, eye straps, etc. but nothing like the very recognizable hardware needed for a tiller pilot.
In case you have no idea what one is: A tiller pilot has a long rectangular body containing a compass, computer chip and the motor and gears to move a push rod that connects to a pin on the tiller. The compass and chip direct the rod in or out to control the tiller and steer the boat. Using a pin on the tiller allows you to lift the tiller pilot's push rod on and off quickly and easily. The body of the device is connected to the boat by a single, vertical, piston like peg that slips into a socket which orients the entire device at 90 deg to the tiller. A tiller pilot needs electric power to operate... and many of them are capable of communicating with other instruments on the boat...so there should be some type of waterproof electrical socket nearby.
You can also look up "tiller pilot" in your favorite search engine to understand how they are mounted in various boats.
Okay.... time to do your homework. Do a survey of your cockpit. then get back and
tell us what other unusual things you found. Then....we'll be happy to tell you how to hook it up and use it.... because... a tiller pilot is one of the very best pieces of kit you can have whether you're sailing short handed or with a full crew.... and if you have one. you need to know all about it. Good luck, have patience.
8
Okay.... time to do your homework. Do a survey of your cockpit. then get ball us what other unusual things you found. Then....we'll be happy to tell you how to hook it up and use it.... because... a tiller pilot is one of the very best pieces of kit you can have whether you're sailing short handed or with a full crew.... and if you have one. you need to know all about it. Good luck, have patience.
Thank you. I do not believe that the boat I just bought last fall came with an auto pilot. Just a tiller clutch. I will be getting back on boat some as the weather get better.
Jun 1, 2004
8,163
So that picture is NOT your boat, is that correct? You just wondered what the peg was for that you saw in some random boat picture. :banghead:
Mar 29, 2022
8
20220331_085706(1).jpg Here is the picture of my tiller. I understand to put a line through the TillerClutch but not sure how to use the peg? Does that help? I do not have an auto pilot that I am aware of at this time.
jviss
Feb 5, 2004
7,089
Gotcha. That pin is for a Raymarine tiller pilot. There should also be a cylindrical, vertical "cup" in the side of the cockpit, unless this tiller came from somewhere else and your boat never had an autopilot. There would also be an electrical connector in the cockpit somewhere.
Mar 29, 2022
8
Thanks. I think you are correct. It never came with auto pilot. But could be hooked up for one.
Jun 1, 2004
8,163
Showing that picture with both attachments now makes sense. You need instructions on how to hook up the tiller clutch. That will answer your question about the pin, However, that pin has been identified by a few other here, and it is in a location where auto pilot tiller pins are normally placed...i.e. on the rear half of the tiller. So here you go: http://wavefrontmarine.com/assets/docs/TillerClutch_OwnersGuide.pdf
My quick glance at the instruction sheet indicated there is no additional hardware needed on the tiller it self, but other pieces on the cockpit seats are needed. It also mentions that the tiller clutch will not interfere with a tiller pilot installation. Any boat with a tiller can be equipped with a tiller pilot.
Mar 30, 2014
37
Catalina 22 Indiana
That’s the setup I have on my 22… works great… except when I move forward and my foot or leg bumps the tiller and the pilot pops off the pin. The two black beadle wraps (one at the end of the pilot, one on the tiller by the pin), when hooked up right, are used to keep it attached.
Likes: Grotto
