A friend and I are half-way through installing a new Raymarine EV-100 Wheel Autopilot to replace my 20+ year old Raymarine ST4000+ autopilot unit that was installed by the original owner of my Catalina 310. A rudder position sensor from the old ST4000+ unit is installed currently. However, a rudder position sensor was not included with the EV-100 package. I read a reference or two online that said the new EV-100 unit does not need the rudder position sensor as the EV-100 system's gyro compass provides sufficient accuracy. Has anyone else installed an EV-100 without a rudder position sensor and, if so, are you finding it works well for you?
I am also wondering if I could connect the existing rudder position sensor to the Sea Talk backbone I am installing for the new EV-100 unit? If so, would it be worth doing? The manual for the older ST4000+ said it used SeaTalk but, I presume a much earlier version so I don't know if the EV-100 is backwards compatible.
Thanks for any help/suggestions.
