I replaced the oil and filter 12 months ago with 15W40 Diesel Oil. I only put 25 hrs on the engine since last change! Does it make sense to change it again this year or is it an overkill?? Thanks.
You do not state which Yanmar model you have but the 3YM30 Service Manual states "150 hrs or one year" whichever comes first. Also the engine lube oil filter will need changing as it is scheduled for 250 hrs or one year, again whichever comes first.I replaced the oil and filter 12 months ago with 15W40 Diesel Oil. I only put 25 hrs on the engine since last change! Does it make sense to change it again this year or is it an overkill?? Thanks.
If your boat gets hauled each season, I believe it is best to drain the oil and replace with fresh at the haulout, regardless of when the oil was last changed. I replace the oil filter at each oil change.
I'll see your contrary and up you two:New oil and filter in an engine that sits is oil that just sits and that is pretty useless.
Makes sense to me. In Northern latitudes, you guys haul out in October and don't splash again until April or May. So the engine is sitting unused with new oil in the pan accumulating condensation; when you start using it again in the Spring, now you have condensation in the oil when you are going to start using it again. Seems to me that changing oil in the Spring would be better. Just conjecture on my part. Guess I would go with the majority opinion. It would be interesting to determine if any manufacturers or repair facilities have a grounded opinion on the proper protocol.The only reason to change it prior to laying up for the season is condensation which will happen with old or new oil so why not wait till commissioning for the season?
If you wait until spring to change your oil, you still have to run the engine first, to warm it up. Now you are dispersing the old contaminants with any condensation throughout the engine. I have never noticed any sign of condensation in the engine come spring. The oil is always clear, and there is no indication of moisture. Anyway, I have 17 years of experience with my Universal diesel and the gas engine of my RV, storing them for the winter, and have had excellent results so far.Makes sense to me. In Northern latitudes, you guys haul out in October and don't splash again until April or May. So the engine is sitting unused with new oil in the pan accumulating condensation; when you start using it again in the Spring, now you have condensation in the oil when you are going to start using it again. Seems to me that changing oil in the Spring would be better. Just conjecture on my part. Guess I would go with the majority opinion. It would be interesting to determine if any manufacturers or repair facilities have a grounded opinion on the proper protocol.
I certainly understand your perspective. I change my oil annually, usually in Spring. Run the engine at dock once a month during off season. No evidenced based research; just what I have always done.Anyway, I have 17 years of experience with my Universal diesel and the gas engine of my RV, storing them for the winter, and have had excellent results so far.
More likely than not it doesn’t matter either way enough to notice a impactIf you wait until spring to change your oil, you still have to run the engine first, to warm it up. Now you are dispersing the old contaminants with any condensation throughout the engine. I have never noticed any sign of condensation in the engine come spring. The oil is always clear, and there is no indication of moisture. Anyway, I have 17 years of experience with my Universal diesel and the gas engine of my RV, storing them for the winter, and have had excellent results so far.
True. But I feel better knowing my baby has fresh oil in her for the winter.More likely than not it doesn’t matter either way enough to notice a impact
You gotta feel good…..True. But I feel better knowing my baby has fresh oil in her for the winter.
