Window Tint for Portlights
Jun 21, 2004
2,838
Beneteau 343 Slidell, LA
Does anyone have experience with using automotive tint film on cast acrylic portlight lens or deck lens?
Does it craze and crack over time? If yes, what's the longevity? If you have used it, any application advice?
Much Thanks.
Jan 4, 2006
7,231
The article refers to "glass" so no real idea as to whether this is acrylic on a sailboat or silica based glass on a powerboat.
Given that plastics are often affected by organic adhesives to the point of permanent adhesion and given that the tinted film is likely to see pretty aggressive temperatures over its life expectancy, I'd be reluctant to try it.
Once had the opportunity to help remove some dark coloured film from the rear window of an old car. It was a bugger to remove with razor blades as each piece was no larger than a half inch square. Acrylic, maybe even worse ?
At present, I'm having white Sunbrella covers made for all of my port and hatch lights to both protect the acrylic and keep the internal boat temperature down to a reasonable level. Better late than never.
Guess I'm just overly cautious.
Likes: BigEasy
Jun 21, 2004
2,838
Probably best to avoid the tint film. Considering the time, effort, and cost to replace the old deck lens, I do not want to have to go through that ordeal again in the near future! Agree that it is a better option to place sunbrella covers. I should have used a tinted acrylic at the time of replacement; however, I didn't locate a source for tinted acrylic until after I had purchased clear acrylic.
Jan 7, 2011
5,505
Oday 322 East Chicago, IN
A PO of my boat put some sort of film on the 2 hatches. While I like the fact that they are tinted, the film is a bit wrinkled where the latch rotates. Looks like the lens is cracked, but it is just the film.
No degradation to the lens as far as I can tell, but I don't know what sort of film was used.
Likes: BigEasy
