Look at the number imprinted on the top of the Sensor head.oes anyone know the part number or length of the sending unit.
Hi Bill, odd, to say the least. Our 1991 has foam on the sides, but none on the top where all the hose connections are located. Unable to tell, but none on the bottom either. The foam on the sides placed to prevent the tank from moving. Should be easy to remove the foam where needed, install the sensing tape on the tank and replace.Hi Peggy...thanks for the info on the Scad Monitor, but unfortunately the tank is completely encased in foam.
