We have a Vitrifrigo freezer. Model BN100BT – DE, Compressor BD50F per label.
According the service tech it appears to have a slow leak and likely will need to be replaced due to difficulty in a fix. Has any one run into this issue? It has kept frozen on the top but not the bottom and it does much better after adding more coolant...for a month or two.
It appears that the unit is built in so the entire counter will need to be removed in order to remove and replace the unit. Is there another option?
Thanks!
Roger
Thanks!
Roger
