Good morning everyone. Hoping for some advice from someone with a mechanical background. I pulled apart my exhaust/ coolant manifold to clean everything up since I was getting a lot of overheating. Unfortunately, when I was bolting the manifold back on to the aluminum coolant reservoir I over torqued the bolt. I have tried to drill it out so I can re tap the hole but I cant get anything that will work. I have used titanium dewalt drill bits and it doesn't seem to do anything. Also since the bolt broke off below the surface (and at an angle) I am doing damage to the aluminum trying to get it out. My question is: Can I just leave it as is? I replaced the gasket and there are 4 other bolts holding it together....maybe it would just leak slowly over time? The only other option I see is buying a new reservoir (500 bucks) and Im not even sure I would be able to get the old one off without breaking more bolts in other locations.
The photo shows the area I am talking about. I circled a bolt in red but the actual location of the broken bolt is in the lower right hand portion of the manifold but cant be seen.
Thanks in advance for any advice.
